help about C++ builder!
lys
Newbie level 2
Newbie level 2
bordbk61.dll
I successfully installed C++ builder 6.0.but it can't run any single program
how this can be possible .the information it promotes is as following
“Application or DLL C:\Program Files\Common Files\Borland Shared\Debugger\bordbk61.dll is invalid Windows iamge .Please check your installation disk”
and when I press 'ok' then “Debugger Kernel BORDBK61.DLL is missing or not registered!”appears!
Does anybody know how to repair it!
thanks!!!!
bordbk61.dll missing
1) On what type of operating system did you install BCB 6 ?
2) Did you choos custom installation ?
If the answer to 2 is yes remove the software and re install as typical
best
bobi
bordbk61.dll is missing o not registered
I meet the same problem, I used the defult installation. When I use regsvr32 bordbk61.dll , it says cannot register, no help file.
ps. I use 64-bit CPU, is that the reason? Will newer builder C software work?
