help !! 4..20mA to 1...2mA
shorty
Member level 2
Member level 2
Austria
Hi everybody
i neet to convert a 4....20mA Sensorsignal
to a 1....2mA Signal
is there a simple way to solve this problem
thanx Shorty
Hi shorty,
You can use a simple modified current mirror, with two ordinary transistors. See the attached PDF file. (Sorry, I couldn't convert it to a directly viewable format).
Your current limits are both shown;
Vcc is 5V;
The current source is your sensor;
The 1k resistor can accomodate any value to interface to your sensor;
The circuit is relatively temperature independent;
I hope it helps...
Regards,
__JR__
Uploaded file: **broken link removed**
thank you very much JR
i never thought that this could be so easy
Shorty
On 2002-04-25 22:48, shorty wrote:
Hi everybody
thanx Shorty
This is a high accuracy way. 😉
