qweets
Junior Member level 2
hello : )
i have been trying different ways to turn a logic held high signal (constant 5v trigger signal)
into a shorter duration ( 7 secs) logic output.
The only way ive found so far, is to use a 555 timer at a low frequency, to pulse a decade counter and have the decade counters second Qoutput reset the circuit after the first Qoutput has sounded a buzzer and led for 7 seconds.
Although this works, the footprint seems very large just to sound a buzzer for 7 secs.. I tried to use a 555 timer by itself; and although i can make a 555 timer output for 7 secs and then stop by itself using a momentary switch as a trigger...as soon as i connect this constant logic trigger signal to the 555 timer, the 555 timer goes around in a seven second loop and never stops.
i just wonder if there is a better soultion?
thanks for your help : )
