Heatsink Thermal Resistance Calculation
MikehZA
Junior Member level 3
South Africa
Hi, I have some Aluminium flat bar that I would like to use as a heatsink. Is there a way to calculate the Thermal Resistance (deg C / W) based on surface area or volume? Regards, Mike.
It's basically the surface area, that matters. In addition, the surface orientation (horizontal, vertical) plays a role. Without forced cooling, the heatsink action is based on air convection. A vertical surface allowing a free convection has a slightly lower thermal resistance for this reason.
The heatsink material introduces additional thermal resistance., particularly when using thin sheets, or generally large length/cross section ratios. The material thermal resistance adds to the heat sink to ambient thermal resistance, but can be often ingnored in a rough estimation.
As a rough estimation, I would expect a thermal resistance of 5 - 10 K/W for 100 cm² surface area.
the way to measure it is too use thermal paste to connect a power resistor to it and get it dissipating.....then you measure the temperature difference between ambient and the bit of the heatsink nearest the resistor..........then you get you kelvin-per-watt value
Reactions: FvM
    FvM
Yes, it's surely the best method to get the thermal resistance of a given heatsink geometry.
