akh_power
Junior Member level 2
I want to select a heat sink for a DPAK MOSFET. The MOSFET is in a PCB which is inside an enclosure without any forced air cooling. So, I think the air flow rate is 0. From the datasheet of one of the heatsinks, I see the following thermal resistance chart.
The top horizontal side of the box is for air flow scale. The right side vertical side for the thermal resistance. From this graph it can be seen that the thermal resistance data is not available for air flow rate less than 200 LFM for the dotted thermal resistance line. Similarly, for the thick thermal resistance line the data is not available for the air flow rate approximately below 70 LFM. What does it mean?
