csdave
Member level 5
hi,
I am turning a bicycle in an e-bike by adding a mid-drive motor and a battery.
To connect the battery to a fuse box and a connector i am soldering the corresponding wires. i am planning to solder each wire (+ and -) with a heat-shrink tube around each. I would then like to put a bigger heat shrink tube around both wires to make a cleaner setup with both wires into a single cable. Is it a good idea to shrink a heat shrink tube on top of two other heat shrink tubes (one for + and one for -) or do I risk melting the inner tubes when I shrink the outer one?
please tell me if my description is not clear
thanks
dave
thanks
dave
