Ronnie
Junior Member level 1
Hi all,
I have a question regarding HDMI layout:
I have a HDMI board I need to layout, this board has just two connector: one connector is to my main board, and the other is a HDMI connector(i.e. this is a HDMI adapter board).
In your professional opinion, if I don't match the lines to 100 ohms will this cause the HDMI to fail?
Consider that the distance between the connectors is about 5MM (one is on the top, the other is bottom).
I usually just take care to match the board properly, however this is just an adapter board, and I'm not sure it's worth the effort.
Has anyone had an experience with such an issue?
