mami_hacky
Full Member level 6
- Joined
- Mar 28, 2002
- Messages
- 337
- Helped
- 18
- Reputation
- 36
- Reaction score
- 11
- Trophy points
- 1,298
- Location
- Some where
- Activity points
- 3,428
Tested HDS 2003.1 under RH7.2, the program works well. The environment has some how changed from the previous versions, a hdldesignerpro license is needed. ( obtainable from mentor HDS site directly or :wink: )
Testing HDS 2003.1 Under Mandrake Linux, results the same error as the previous versions, also this is the same as what happens when you try to run HDS under RH8, "Can not create FontSet .... , The following characters can not be shown..." I tried a lot, to some how run the program, first, I installed lots of different fonts, and then I found out that we can change the HDS's fonts using one of its configuration files, the result for all of these efforts was that this error does not relate to a special font, and it's source is some where else. Then I tryed some of .so files from RH7.2 on Mandrake 9.1, specially those .so files which had a "font" word in their names, OK! agian this time nothing obtained.
Testing HDS 2003.1 (Windows Version) under Windows 2003 Server, a fantastic error message appears: "The system date has been set back" however all of the other programs which use flexlm work well, ( those such as amplify ) and I'm wondering, I have never changed my system's date.
Testing HDS 2003.1 ( Windows Version ) under Windows XP, every thing is OK.
We should work more on the new HDS's environment, so that we can find out, the improvements to the previous version.
Any body can guide me, about the linux font system and specially describe what is a FontSet?
