HDL-93 HDL-180 - how to deal with the warning
visualart
Advanced Member level 1
HDL-93 HDL-180
I miss the scriptor synthisis the Cusb IP core by synopsys.
Can you help me?
When I run the DC, it report many warnings as follow:
"Potential simulator-synthesis mismatch if index exceeds size of array. HDL -93"
"Variable 'a' is being read in routine .... , but does not occur in the timing control of the block with begins, there. HDL-180"
How can I deal with the warnings?
Tia
For HDL-93 warning, if you are sure that your index is never gonna exceed the size of array declared, then you may ignore this warning. As for HDL-180, variable or signal 'a' is not included in the sensitivity lists, you will need to fix this warning. At the end of the day, any mismatch can be captured by running gate-level simulation or formal verification.
Thx jkfoo.
About the HDL-93 , I may ensure and ignore them.
the HDL-180, they are error, when i write as follow:
always @(a[0] or a[1])
begin
b = a
end
Why the varbile 'a' Can not write by 'a[]'?
visualart said:
Thx jkfoo.
begin
b = a
end
Check bus "a" 's width. If bus "a" is from bit 7 to bit 0,
Solution 1:
You need to put all of them in "@(...)" block.
Solution 2:
always @( a[0] or a[1[] )
begin
b[0] = a[0];
b[1] = a[1];
end
Solution 3:
begin
b = { a[1], a[0] };
end
Some of them may be not 100% correct, but I just want to give you some possible solution.
--Abner--
Verilog Syntax
> begin
> b = a ;
> end
OR may just write, ( For a[1:0] and b[1:0] )
always @(a)
begin
b=a;
end
[Tool will check the length of the variables a and b anyway...]
Oh, Thx all.
My code as follow:
reg [10:0] a[3:0];
reg [1:0] b;
reg [15:0] c;
always @(a[0] or a[1] or a[2] or a [3])
reg [1:0] x;
begin x = b;
case( x)
default: c = {4'b0, a[x]} ;
endcase
when I compile, It infor me above information(HDL-180).
Why?
How can I revise it?
Tia
how about,
always @(a[0] or a[1] or a[2] or a [3] or b)
