sandofsad
Newbie level 6
Hi, i'm stuck on this problem. i try to boost data and adress from controller board to an eprom 27c256. From the controller board it signal, data and address will be boost using HC573A latch ic.
here the theory i try to solder up the component. All address input and address data from eprom 27c256 will be connected to HC573A input. And all HC573A output will go to eprom same pin and sequence from controller board. But HC573A OE pin 1 and LE pin 11 here should i connect?
