has anyone used ADV7123 video dac
s3034585
Full Member level 4
Full Member level 4
adv7123 application
Hi Guys
Has anyone used a adv7123 Video dac. I have a dought in its application circuit.
Pin 36 is Vref and it is connect to VAA using a 0.1uF cap. Why is it so. I couldnt understand the reason behind it. Similar is the case with pin35 COMP.
Can any one pls let me know about it.
Thanks in advance
tama
adv7123
See the attachment, on ADV7123. Whatever mentioned in the document follow them.
If you need more information, contact me.
Regards,
N.Muralidhara
how to use adv7123
I have not looked at the data sheets provided by muralicrl. But I have used similar Ic's and the vref has a dual function. It can output the internal voltage reference or it can supply a different external reference. If you do not use it they suggest connecting the cap to it for decoupling purposes. The cap on the comp pin is purely for decoupling purposes
@ s3034585
We use the ADV7123 in several applications. For example here:
It is a very stable DAC which never caused any trouble.
ep20k
Download the application notes from here
