Hardware pcba evaluate tool, technical HDMI, USB, RAM
noisepic
Member level 3
Member level 3
Hardware pcb evaluate tool, technic HDMI,USB,RAM
I'm going to do a project to build hardware design for set top box using core arm chip. The peripheral including connecting to Memory, USB, SD card, HDMI.
Schematic is not difficult build due to available reference by chip vendor, but I don't know how to evaluate, bug when PCBA comes. Do you know?
Thanks
Re: Hardware pcb evaluate tool, technic HDMI,USB,RAM
First of all you have to be fully aware of manufacturers layout recomandations for these chip. For SDcard I believe that you'll not worry much about, although its clock is specifiead to reach up to 25MHz. However, for USB and particularly for HDMI ( assuming you made routing following specifications ) I'll not doubt that at least one of these ICs has pins output for eye pattern, so that you could compare if it is under specified tolerance.
Thanks
hope you are not worrying about the PCB layout ,but the testing of assembled boards. You may face multiple issues while board bring up right from the power supply. following links gives some basic idea about board bring up.
