Handel-C Vs Verilog Speed Difference!
CMOS
Advanced Member level 3
USA
I just tried this simple LED blinking code in Verilog and Handel-C. The result I got was stunning. The verilog version blinks LED at much faster rate than Handel-C version on the same FPGA board. Can anyone explain the reason!
Here are the codes
1. Verilog
module LEDBlink(led1, led2, clk);
input clk;
output led1;
output led2;
reg [23:0] cnt;
always @(posedge clk) cnt<=cnt+24'h1;
assign led1 = cnt[20] & cnt[22] & cnt[23];
assign led2 = cnt[23];
endmodule
2. Handel-C Code
set clock = external "10" with {rate = 24, standard = "LVTTL"};
unsigned int 1 led1;
interface bus_out() led_pin1(unsigned int 1 led_pin1 = led1) with {data={"97"}, standard = "LVTTL"};
unsigned int 1 led2;
interface bus_out() led_pin2(unsigned int 1 led_pin2 = led2) with {data={"91"}, standard = "LVTTL"};
void main(void)
	unsigned int 24 cnt;
	while(1)
		cnt++;
		led2 = cnt[23];
this is because handle-c is sequental you should put a par statement
par
x
y
x
    CMOS
does this mean you cant put parallelism in your design with Handel-C???????????
it actually say you can, just remember to put the par { } before
assigments.
okay so par means parallel??? is that right?
Yes par = parallel and seq = sequential. By default all statement execute sequentially unless written in par block.
par
x
y
x
Yes that works! Silly me..how could I forget that thing :D Thanks.
One more thing. Can you tell me how do you define high impedance state in Handel-C. I want to convert this Verilog statement to Handel-C,
assign FX2_FD = FIFO_DATAOUT_OE ? FIFO_DATAOUT : 8'hZZ;
AN EXAMPLE FOR BUS :
interface bus_ts_clock_in (int 4 read)
BiBus(int 4 writePort=x+1,
unsigned 1 enable=condition)
with {data = {"P4", "P3", "P2", "P1"}};
condition = 0; // Tri-state external pins
x = BiBus.read; // Read registered value
condition = 1; // Drive x+1 onto the pins
    CMOS
EDALIST, you seem to be a Guru of Handel-C. I will try that out. :)
Hey EDALIST, can you name some good tutorial/e-book/book on Handel-C? The Celoxica manual doesnt seem complete as I cant find many things in it. Our school has DK2.0.
here is dk 4 handlec user guide
