udhay_cit
Full Member level 6
I am using Ltspice for my simulations. I have simulated a halfwave rectifier with two diodes as shonw in the circuit diagram. While measuring output waveform at node 1 with reference to ground i am getting a negative peak of 6v. I am so confused, where the negative peak come from..! The two diodes are acting like a diode potential divider.
Anybody explain me.... Is it the simulation tool problem? can anybody simulate the same schematic with some other tool?
Regards
Udhay
Regards
Udhay
