gb_R
Newbie
I'm trying to make a half bridge power supply . after a year of learning, now every thing looks perfect when i run it at 45V DC bench power supply but when i run it on mains (240AC) the low side IGBT get hotter then the high side one ( I don't have a temp meter at the moment but it looks x2 times hotter then high side one when i touch the heatsink ). I swap the IGBT and the other components low side to high side but the issue always stays on the low side. GDT voltage and signals are same on both side. only the difference is the low side IGBT to GDT tracks are about 3cm longer then the high side one. could that be the reason ? ( every thing looks perfect when i run it at 45V DC bench power supply, both IGBT equally warm ). Regards
