[SOLVED] h-bridge simulation ugly signals
d123
Advanced Member level 5
Spain
At first glance does anyone recognize what the cause of the horrible h-bridge signals (VF5 and VF6) are being caused by? I put plenty of dead-time in there, as can be seen from the immaculate gate signals, 1H + 1L and 2H + 2L - nothing coincides where it shouldn't and what has to be off is off and what has to be on is on at their expected times. How can there be shoot-through when e.g. T1 and T3 never coincide in being on? I assume it's something obvious and I'm being thick not understanding what I'm being shown by the simulation. Either I can't see something I should by now or I don't understand what ugly 5 and ugly 6 mean here. VG1 is 10 Hz, the inductor has 40 Ohms of resistance, fwiw as information. I'm probably really trying to learn about implementing dead-time and assorted configurations that can achieve that, not making a discrete h-bridge.
Thanks.
1k Ohm gate resistance is much too high.
and the 22k to sssslllloooowwwwlllyyy discharge gates makes it worse.
Klaus
Reactions: d123
    d123
You will hardly be able to implement the gate driver delay with just one transistor stage, it is necessary a saturation circuitry somewhere; you could rather consider a Schmitt trigger arrangement, or since you are supplying the logic with 5V, you could simply replace the 4 MOSFET's with a single IC gate ( e.g 4000 series ) instead.
Reactions: d123
    d123
    c_mitra
may I ask what´s the idea behind this circuit?
Why build such a circuit and what is it used for?
My thougths:
* .. because there is no "ready to buy" solution. But I guess there is.
* .. because it´s cheaper than the "ready to buy" solution. But if you take all the effort and parts into account...
* .. it has some benefits against the "ready to buy" solutions. I don´t see..
Especially the big capacitors C1, C2 do not only delay the signal, they cause low rise and fall rate.
But this low rise/fall rates cause high power dissipation during switching (switching loss). So while the MOSFETS with their low R_DS_ON generate low heat when ON (conduction loss) but maybe much more swtiching loss.
When driving inductive loads you may avoid DC in the ouput signal. Due to capacitor (and other components) tolerance one side may be faster than the other ... unsymmetric timing, which may cause unwanted DC.
Even if you want to build your own circuit I recommend to read through some "ready to buy" parts datasheets and according application notes. To find out and avoid the pitfalls.
Klaus
Reactions: d123
    d123
I was just exploring implementing dead-time. Maybe to make a 'clock' that never moves forward in time, just one tick forwards and one tock backwards forever; it would need to be with a stepper motor anyway, not the 'motor' in the schematic, so the drive circuitry would be different. Main interest was wave shaping for dead-time and an h-bridge seems a good circuit to see if that is working correctly or not. Apart from what you mention about avoidable switching losses I see it's a flawed design, anyway, previous comments drew my attention to a couple of important design aspects - the VF1 from the VG1 signal needs to be turned off before the VF2 from the VG2 one starts (and vice versa) as well as turning off the bridge MOSFETs far faster. Bad design.
Reactions: d123
    d123
