kbtan
Member level 2
Hi, I am using a H-Bridge with 4 transistor(2 TIP31a, 2 TIP32a). Following is my circuit
I supply 12V to the collector of TIP31a and 3V to the base. Then motor will start run when I supply 3v to one side and other side to ground,but it run at about 2.3V instead of 12 V. How can I make the motor run at 12V???
