bunalmis
Full Member level 5
h bridge current sensing
I use H bridge and inductive load. Waveform of load current is sinusoidal and frequency is DC to 1 KhZ. (I use sinus modulated pwm signal.)
I add small resistor to gnd line for sensing current. Voltaje drop on the this resistor is proportional by current of load, but this voltage drop does not give any idea for current direction.
I take samples from resistor voltage at the every 20 microsecond.
Current magnitude and direction are very importand data, because i use this two values for feedback value of current regulator.
Inductance current waveform is sine wave and current and voltage not same phase. (Frequency range between DC to 1Khz)
How I can learn the current direction?. (indepented from load type.)
I dont want to use expensive sensors (LEM, HP or IRF current IC)
Dou you have any simple idea for this problem?
I dont want to use current transformer because load current may be DC if i reduce the frequency.
(H bridge voltage value is 100V)
