swethasunil
Newbie level 3
I want to generate full bridge inverter circuit using MOSFET driver IR2111.I know the half bridge circuit connection using IR2111.In the half bridge circuit,upper and lower switch in a leg are driven using IR2111's HO and LO pins.In full bridge, 2legs.Is it possible to connect the 2 legs using 2 separate IR2111,i.e.one leg's upper and lower switch using one IR2111 and another leg using another IR2111.Is it correct?.Is there any synchronisation problem?Can any one help me.
