HelpMe2020
Newbie
Hello All,
I am new to the community and this query would be my first post on the forum. So, apologies in advance if I not strictly adhering any guidelines.
I have designed this H-Bridge and corresponding PCB was also fabricated. I simulated it on LTSpice, too. It has two variations with +12V and +24V supply. I have tested it and it has been working fine driving various DC motors. However, sometimes (randomly and sporadically on both +12V and +24V) with no load i.e no motor connected, the one side of H-bridge (both P-MOSFET and N-MOSFET) would fry out together very bad, and then those two MOSFETs are actually gone bad. I'd replace those two MOSFETs with new ones and it would start working again. Next time, randomly, other side would burn out. However, I never saw it failing or heating out whenever it starts working once and load is connected. It would work seamlessly. It randomly fries out only when no load is not connected. (Always right away when I insert +12V or +24V supply into it --> Again, randomly burns out). It would fry out right away after voltage supply is inserted if it has to otherwise it wouldn't. It never fries once the voltage is provided and circuit is stable. It would fry only randomly and immediately when +12V/+24V supply is inserted. Could this be random inrush current? Could this be mismatch of Rds? Let me re-emphasis that both the MOSFETS from one side fries out together.
Please recommend changes that might fix this solution. Any recommendation will be greatly appreciated!
Note: The above experience happened when M1 and M2 were AOD4189. I have changed the P-MOSFETs to the new ones (IPD068P) with matching Rds that of IRLR8726 to avoid shoot-through. I haven't tested the changes. I want to be double sure that I am not missing something else.
