Ducados
Junior Member level 1
I'm trying to create a univibe tyoe of guitar effect. That will consist of a timebase i.c. that will vary the sound to create a tremelo effect and various other phasing sounds. (Variable speed 1 to 30Hz)
The trouble is I can't get it past the breadboard, although it works well enough I cannot avoid the sound of the I.C. switching, whether it be a 4046 VCO, an NE555, hc7417, 4093 or whatever, it just produces a tick, tick, tick in the background.
Even if the IC is not connected to the guitar circuit, the tick sound still persists, even though the guitar circuit only shares the ground connection with the IC.
I suppose I could fix this by putting the IC on another power source and using a vactrol but that would make the project too complicated.
Any suggestions how to reduce this noise?
