UroBoros
Advanced Member level 2
- Joined
- May 5, 2004
- Messages
- 642
- Helped
- 19
- Reputation
- 38
- Reaction score
- 8
- Trophy points
- 1,298
- Location
- Cochin - India
- Activity points
- 6,463
op amp stages
Hello
I need to measure current through R1 by measuring the voltage across it. Range is 0 to 500mA current.
I propose to use a .1 or .2 ohm resistor there.
So voltage developed will be from 0 to 50millivolt or 100 millivolt.
I need a resolution of .1mA .So plans to drive MCP3304 in pseudo differential mode.
The voltage range I need to obtain at the input of ADC is 1 volt to 4 volt.
Please give some guidelines to derive my design.
I am using Proteus to simulate my design.(Learning)
Thanks a lot
Hello
Thanks a lot
