Dear All
I would like to start to build a line follow bot
Can any body guide me
My MCU is 16F877a
I think like this
Hopes to use PORTB with portb change interrupt
Hopes to use six Ir sensors to find line
Hopes to use two DC motors
Use L293 as DC motor driver
Dear All
I red all website that you provided
so I decided to use LM324N as sensor driver
LN293 as motor driver
and decided to use 8 sensors
can I know any programming Technic using assembly
---------- Post added at 23:37 ---------- Previous post was at 23:12 ----------
Dear Bradthered,
Thank you very much for reply
using two sensors. I think, it may be swing the bot
how do you manage the swing ?
can I have more advice
Dear Bradthered,
I no longer have the robot, but I remember it used an op amp (maybe two op amps) to sense the difference between two light sensors. These were mounted side by side, resting on the floor in front of the robot.
When one sensor saw dark, the other saw light. The op amp responded to keep the sensors equally illuminated. In the one case it turned on the lefthand drive motor.
In the opposite case it turned on the righthand motor. Response was fast, and the robot fishtailed a little from side to side as it travelled. It could go a couple inches per second.
There is the need for the robot to be able to acquire a line. This means allowing a sensor to see dark and yet not change the direction the robot is going. As I think about it, this was designed to happen naturally. No need to make the control circuit switch to 'acquire' mode. Anyway I remember that the robot would drive in circles until a sensor picked up a dark line.
We have developed a line follower robot with pic 18f series Which uses only two infrared transceivers .it has better controll and live programing feature.I think there is no nessecity for 8 sensors.with two sensors we can make a highly accurate one
It may be;but in the case of our robot I can say that it doesn't happened yet .probably the motor speed and chasis alignment determines it,but using differential speed control we can make a perfect line follower robot with two sensors.I gaurantee it.it's not much complex and reliable I think;
We have designed an IR transceiver for these purpose .I think the simplest method to trace the track accurately is by the use of IR transceivers .there are no more sensor driving circuit is needed just a 555 astable multivibrator and a tsop receiver
Definitely,
It is the best suitable method for these type of applications.
In the case of pic there are PWM contol registers which made it much easier!
