vikash23
Full Member level 2
Hi ,
I am bit confused with the PCB layer stack up.
The setup I have got now is
1. Top
2. Power
3. Ground
4. Bottom.
I wish the setup can be (referred several stack up guide )
1. Top
2. Ground
3. Power
4. Bottom.
The reason is I have components only in the top and power tracks running on the top except few long power tracks on the power layer 2. So if the ground layer is very next to the top i feel there will be a good flow of current path.
So which setup do I need to go for.
1. Top
2. Power
3. Ground
4. Bottom.
1. Top
2. Ground
3. Power
4. Bottom.
