quidance about designing the board more than 4 layers
Look in the forum for Johnson's book on High-speed digital design for starters, and read that. But the layer stackup will depend on how many signal layers you need. If you have more than 3 VCC's, you will have to probably partition your planes into multiple power islands. Determine what VCC's are the most important and most used, and those should get a whole plane to themselves, or at least most of it. For clocks, it is important that the return paths are very clean, meaning that they should be adjacent to a ground layer, and have as few via's as possible. If it must jump from layer to layer, keep it always on layers that are adjacent to ground planes. These are just some rules to keep in mind...
