Lucifre
Full Member level 2
- Joined
- Jul 5, 2005
- Messages
- 125
- Helped
- 2
- Reputation
- 4
- Reaction score
- 0
- Trophy points
- 1,296
- Location
- Detroit MI
- Activity points
- 2,389
i have a mosfet with source grounded, +5 v and led with resistor connected to drain. when i apply 5v to the gate transistor turns on... the problem is when i want to turn it off... when i remove the wire from the gate led still glows when i ground the gate it turns off, but it turns on again as soon as i disconnect the wire from ground. I knoe the transistor is ok because i bought two of them and both of them act the same way. Is that the way mosfet should work? i thought that if you disconnect the wire from the gate it would turn off.
