kender
signal of photo diode
Colleagues,
Could you recommend a technique for guarding a signal from a photodiode in photovoltaic mode? The photodiode signal will be close to DC. The photodiode will be connected with a 15cm cable. Environment is not expected to have a lot of EMI. I’m expecting photo currents in nano-amperes, I’m afraid that leakages will distort my readings, and I would like to add a guard to the photodiode signal.
The plan is to have a shield around cathode line, which is driven with a cathode voltage through a buffer (guard buffer).
Do you think this can work? Any suggestion and insight is appreciated!
- Nick
Colleagues,
- Nick
