GSM interfacing with Virtual Serial Port Emulator
ananthrajv
Newbie level 1
I have written the code for GSM integrating with PIC and connected the GSM to the pc through VSPE. the code is working fine except the last portion of the transitter section.
the normal GSM code is working fine but integrating with few extra peripherals like keypad and LCD its not working .
my code simply if we enter 3 digits in the keypad if its is correct the output will display correct.
if not it has send the message to the number.
The GSM initializing is doing correct but the message transmission is not working .
I have pasted the code below ..
please help
#if defined(__PCM__)
#include <16F877A.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use DELAY(CLOCK=16000000)
#use rs232 (baud = 9600, xmit = PIN_C6, rcv = PIN_C7)
#define C1 PIN_c0
#define C2 PIN_c1
#define C3 PIN_c2
#BYTE PORTA = 0X05
#BYTE TRISA = 0X85
char keypad();
void display_enter();
void display_correct();
void display_wrong();
char M[3],x,c;
int i,j,k;
char at[]="AT";
char cmgf[]="AT+CMGF=1";
char cnmi[]="AT+CNMI=2,2,0,0,0";
char cmgs[]="AT+CMGS="+919500808111"";
char msg1[]="WELCOME";
void lcd_init();
void comand(char c);
void gsm_tx();
void gsm_init();
void main()
gsm_init();
delay_ms(1000);
lcd_init();
delay_ms(1000);
while(1)
display_enter();
delay_ms(1000);
lcd_init();
while(1)
for(i=0;1<=3;i++)
M=keypad();
printf("%c",M);
comand('*');
delay_ms(100);
if(i==2)
if((M[0]=='0')&&(M[1]=='1')&&(M[2]=='2'))
printf("open");
lcd_init();
display_correct();
output_bit(pin_b0,1);
else
lcd_init();
display_wrong();
output_bit(pin_b2,1);
gsm_tx();
char keypad()
int a=0;
char C;
do
//ROW 1
output_a(0xfe);// ROW 1 1111 1110
delay_ms(5);
if((PORTa|0xfe)==0xfe)
if(input(C1)==0)
C='1';
a=1;
while(input(C1)==0);
if(input(C2)==0)
C='2';
a=1;
while(input(C2)==0);
else if(input(C3)==0)
C='3';
a=1;
while(input(C3)==0);
// ROW 2
output_a(0xfd);
delay_ms(5);
if((PORTa|0xfd)==0xfd)// 1111 1101
if(input(C1)==0)
C='4';
a=1;
else if(input(C2)==0)
C='5';
a=1;
C='6';
a=1;
//ROW 3
output_a(0xfb);// ROW 1 1111 1011
delay_ms(5);
if((PORTa|0xfb)==0xfb)
if(input(C1)==0)
C='7';
a=1;
if(input(C2)==0)
C='8';
a=1;
C='9';
a=1;
//ROW 4
output_a(0xf7);// ROW 1 1111 0111
delay_ms(5);
if((PORTa|0xf7)==0xf7)
if(input(C1)==0)
C='*';
a=1;
C='0';
a=1;
C='#';
a=1;
}while(a==0);
return(C);
void lcd_init()
output_bit(pin_e0,0);//register select - Control Register
delay_ms(10);
comand(0x01); //Clear Display
delay_ms(1);
comand(0x06); // Entry mode
comand(0x38); // Function set
comand(0x80); // Starting Address for 1 row
comand(0x0F); // c on d on b on
output_bit(pin_e0,1); //Data register
void comand(char c)
output_d(c);//d=data
output_bit(pin_e1,1);//enable to send data to LCD
delay_ms(1);
output_bit(pin_e1,0);
char a[]="enter the keypad";
for(i=0;i<=16;i++)
comand(a);
delay_ms(10);
char a[]="correct password";
for(i=0;i<=16;i++)
comand(a);
char a[]="wrong password";
for(i=0;i<=16;i++)
comand(a);
void gsm_init()
//at
putc('\n');
delay_ms(2000);
for(i=0;i<2;i++)
putc(at);
x=getch();
putc(0x0d);
do{
x=getch();
}while(x!='K');
output_bit(pin_b7,1);
delay_ms(2000);
output_bit(pin_b7,0);
delay_ms(2000);
delay_ms(10);
//cmgf
for(i=0;i<9;i++)
putc(cmgf);
x=getch();
putc(0x0d);
do{
x=getch();
}while(x!='K');
delay_ms(2000);
delay_ms(2000);
delay_ms(10);
//cnmi
for(i=0;i<17;i++)
putc(cnmi);
x=getch();
delay_ms(3);
putc(0x0d);
do{
x=getch();
}while(x!='K');
delay_ms(2000);
delay_ms(2000);
delay_ms(20);
void gsm_tx()
i=0;
//cmgs
for(i=0;i<23;i++)
putc(cmgs);
x=getch();
delay_ms(3);
putc(0x0d);
do{
x=getch();
}while(x!='>');
delay_ms(20);
//message
for(i=0;msg1!='!';i++)
putc(msg1);
x=getch();
delay_ms(3);
putc(0x1a);
do{
x=getch();
}while(x!='K');
do{
x=getch();
}while(x!=0x0a);
delay_ms(2000);
delay_ms(2000);
please help to move on this..
