kmalone
Newbie level 1
I'm making a guitar preamp and I'm powering it from a 12v SMPS (Switched mode power supply) (Meanwell NES-15-12). The ground i'm using in the circuit is the negative terminal of the SMPS. I'm getting a lot of noise when i connect the guitar to the preamp through a coaxial cable even though the strings and shielding are grounded (to the negative terminal of the SMPS). I was wondering if I could connect the negative terminal of the SMPS to earth/ground on the AC line, would this a) work/ not blow up or short and b) reduce the noise?
