vaibhavpawar
Junior Member level 1
I am working on a project called biochemistry analyzer in which there are many PCBs like Main Board, Photo detector (ADC) board, Printer PCB, LCD, Smart card board etc. In this application, power supply regulator IC's are on Main Board from which Gnd is shared between multiple PCB's through jumper.
There are various possibilities how I deal with Ground trace and plane.
Possibility 1: Complete bottom layer of Gnd plane on Main Board ( where regulator chips are located ) and through jumper taking gnd to another board and then using trace ( instead of plane)
Possibility 2: Assigning plane on All PCB's but this will be little cumbersome and I don't know whether it's good idea or not.
If there is any other option which will be best suited because this instrument is analytical analyzer where precise ADC is required and photodiode is used.
So please suggest good grounding scheme.
