mitul121
Newbie level 5
grounding my project
I currently have a set up where I have attached a permanant magnet dc motor to a bicycle. The motor is attached through a diode to a 12v regulator and then to a 12v to 240v inverter. Everything works fine and I can power up my devices. I also have a lead acid battery as a back up source.
Everything is now mounted in a metal box ( apart from the motor which is on the bicycle). Please can someone help me on how to ground this case?
I know this may seem a bit basic but I am in the learning process still, so any help will be appreciated.
Thanks
Mit
Thanks
Mit
