eng
Junior Member level 1
multicore copperset
Hello everyone,
I have designed a balanced low noise amplifier.
The specifications of my design:
-2.4 Ghz, min 10 db gain, max 2.5 db noise figure
-microstrip technology
-substrate rogers 6002, 60 mils thickness
-1A1306-3 couplers fron Anaren corp. (balanced amplifier)
This amplifier was manufactured with milling machine.
I need some practical informations.
First of all I have no equipment to drill a grounding via so I have to do it manually. For good grounding what are the things that I should do?I think in order to have couplers working properly I need a good grounding.
Also for soldering what kind of tricks can you recommend? I will do a lot of soldering stuff because there are so many lumped components; 2 couplers, 4 capacitors, 4 resistors (to get 50 ohm termination I'm using 2 x 100 ohm parallel) and 2 transistors.
Thanks in advance.
Regards,
Hello everyone,
Thanks in advance.
Regards,
