Ground trace on pcb
jmx66
Member level 5
Member level 5
France
In a 20-Amp power supply, use the thickest conductor available, and connect the marked points by screws to a thick aluminum chassis. Also make sure the grounds in the AC input and DC output connectors are connected this way.
Reactions: jmx66
    jmx66
Hi jiripolivka,
Thanks a lot for your reply.
So, i must add a kind of '' bus copper bar '' - or aluminium - like in aircraft electric circuit?
Regards.
Jm
Hi jiripolivka,
I'm designing pcb copper trace with a thick aluminium bar, to withstand these 20 A.
Next question will be the best of 2 drawings planed: mainly sharing load on the first or the entire resistors net.
I'd like to use Case 1 - one single pcb copper trace + aluminium plate - due to space constraints, than Case 2, is it a good choice?
In Case 1 , is current sharing evenly in all the resistors, or only through the first one????
Avoiding frying some component or pcb trace would be nice ..
Also, copper and aluminium are dissimilar materials, so, no electrolytic corrosion?
Thanks you for your help, it's great.
jm
