arefeidi
Member level 4
I'm doing the layout for a UHF-circuit (~1GHz) on a two-layer pcb. The bottom layer will be used as ground plane, though I'm not sure what to do with the unused areas on the top layer.
a) Should I remove all the copper and leave the areas blank
b) Or should I use them as additional ground, connecting them to the bottom layer with vias?
If the answer is b, how much vias should I use to connect the additional ground areas to the main ground plane – is one via enough per ground area on the top layer, or should I use several vias to connect each ground area?
Thanks alot,
arefeidi
Thanks alot,
arefeidi
