peteryuan
Newbie level 3
I am design a micro strip patch antenna for UWB application (3.1-10.6GHz) in CST.
The substrate is Rogers RT 5880 and the feedline, patch and ground plane is Copper (Annealed).
The feedline is Micro Line Feed.
the is result for S-parameter is accepted but the z-matrix(impedance) is around 40ohms
but my minimum tolerance is at least 0.5mm and the impedance is 50 ohms.
How & what is the dimension of the thickness of the patch, feed line and ground plane for that specification as mention above?
What other improvement can be made?
