anh56789
Junior Member level 2
I want to evaluate the performance of the inductor with the effect of the ground shielding similar to this post: https://muehlhaus.com/support/rfic-em-appnotes/inductor-ground-cutout
But I'm confused about how to define the voltage for grounding metal around the inductor. Below is the inductor test bench of the post
In the test bench, I don't see any pin connected to the surrounding metal. So how could we know that the metal is connected to the ground? Is it a floating metal?
What if I want to use a port to define the GND for the surrounding metal? below is a picture of my layout. In this layout, I use ports 3 and 4 for defining the voltage of the surrounding metal.
Is it the correct way to set up the ground for the surrounding metal? Any insights on this problem would be appreciated. Thank you!!!
