123jack
Advanced Member level 2
I wasn't sure where to ask this - I hope this is ok.
I've not used a MAX232 before and was wondering about noise levels.
Obviously the charge pump is going to create some noise but I'm
seeing +200mV -50mV oscillation on the power/ground lines.
I was wondering if this is normal?
I have tried extra decoupling and keeping the caps close to the chip etc
but nothing seems to help. The 5V supply is clean offload and I've tried the chip
in isolation on breadboard with the same results.
I've tried 3 different versions of the chip - 232N 232CPE and 232NG
Does anyone have any experience or comment on this?
If it is normal is there a standard way people clean it up?
Are the 3v surface mount versions much cleaner?
cheers
jack
cheers
jack
