pigtwo
Member level 4
Hello all,
I'm working on a board that uses USB to send data to and from a computer. Power is supplied not through USB but an external isolated power supply. I'm having some weird problems with my scope while measuring on the board. The scope will randomly turn off and then won't turn back on unless I switch the power cord(makes no sense to me). This doesn't happen immediately and the scope can be running for hours before it will turn off.
So I thought maybe there was a problem with the grounding. I'm pretty sure the USB isn't isolated so the ground on my board is earth ground. I also know that the scope ground is earth ground so I can't just put my ground clip where ever I want. I must connect it to ground and this is what I've been doing the whole time. So I measured the current going through the scope probe ground and it is about 10mA. Is this a reasonable amount? I'm not sure why there would be a difference between these grounds such that it would draw that much current.
I have verified that the power supply is isolated and with just the scope and power supply plugged in there is no ground current.
Hopefully someone has seen something like this and can give me some insight.
Thank you!
Thank you!
