Hi
I am working on GPS/SMS based vehicle tracking system using XAG49 (micro-controller).
confuse with UART0 and UART1?
i am going to connect GPS to pin1.4 n pin1.5 is it UART1?
i try to work on this UART1 with 4800 baud-rate i calculate the values of TH1=0xff and TL1=0xdc are they correct?
Now how to receive data from GPS using C code? I am using RIDE software.
yes dude i can do help but i can help in only avr and codevision avr...
but this projects is so cool
in that case if you are confusing with two uart then use single uart first then use soft relay timely to switch between these two uart
I am also not able to get data by GPS...
Will you able to help me code for 8051 or ARM...?
Actually I am confuse how get the data and manage it in proper way like its latitude, Altitude, longitude and data & time.
I will manage the UART functions tell me the logic please..?
