Hi !
If anybody working on GPS Receiver Holux Br89 or already worked on this project then please share the schematic to see GPS Data on Hyper terminal.
Hi, antenna's RF signal you have to connect to pin 17.
Pin 19 and 20 is used to supply power for active antenna.
If you are using passive, just leave them open. If active- you have connect pin 19 to pin 20.
Im working with holux M-89 and already getting gps strings.
Good luck.
Thanks for the answer but can u share your schematic of Holux M-89 GPS Receiver, because this will clear all the problems and willl be helpful in my project.
