pawan kumar
Member level 4
- Joined
- Jan 31, 2012
- Messages
- 73
- Helped
- 5
- Reputation
- 10
- Reaction score
- 5
- Trophy points
- 1,298
- Location
- Chennai
- Activity points
- 1,894
#include<lpc214x.h>
void inituart1() //initializes both UARTS at 9600 baud
U1LCR=0x83;
U1DLL=0x61;
U1DLM=0x00;
U1LCR=0x03;
U0LCR=0x83;
U0DLL=0x61;
U0DLM=0x00;
U0LCR=0x03;
void send(unsigned char a) //sends a byte through U0
U0THR=a;
while(U0LSR!=0x60);
void senduart1(unsigned char a) //sends a byte through U1
U1THR=a;
while(U1LSR!=0x60);
unsigned char recuart1() // recieves a byte from U1
unsigned char p;
while ((U1LSR&0x01)!=1);
p=U1RBR;
return p;
unsigned char rec() // recieves a byte from U0
unsigned char p;
while ((U0LSR&0x01)!=1);
p=U0RBR;
return p;
int main()
PINSEL0=0x00050005; //initialized U0 and U1 as UART and not GPIO
PINSEL1 = 0x00000000;
PINSEL2 = 0x00000000;
inituart1();
while(1)
send(recuart1());
while(1) {
send(i);
i++;
if(i == 'Z'+1) {
i = 'A';
send(0x0D);
send(0x0A);
Of course you need to test the GPS outdoors.
that's really cheap.. I used to think a scope was never less than 600USD..this is news bro! but my project constraints now : I promised to show 50%completion of my final year project by 10th feb..I am not able to communicate any peripheral with ARM. it does with PC.I would ve been happier if it did not work with P.C either.I feel like having a choke throat after crossing half the river......
#include<lpc214x.h>
void init() //initializes both UARTS @9600,8bit, no pairity,1 stopbit
U0LCR=0x83;
U0DLL=0x61;
U0DLM=0x00;
U0LCR=0x03;
U1LCR=0x83;
U1DLL=0x61;
U1DLM=0x00;
U1LCR=0x03;
void senduart0(unsigned char a) //sends a byte through UART0
U0THR=a;
while(U0LSR!=0x60);
unsigned char recuart1() //recieves a byte from UART1
unsigned char p;
p=U1RBR;
return p;
int main()
unsigned char p;
PINSEL0=0x00050005;
init();
while(1)
p=recuart1(); //receive something in UART1
senduart0(p); //send the same to UART0
2. You should flip the connections of microcontroller side max232 while connecting to modem
