GPRS unable to compare "OK" commands.
Rohi231
Member level 2
Member level 2
Hello . I am interfacing GPRS with add semiconductor. I am unable to compare the "OK" commands. When i put
len=strnlen(rec);
what will be the length of len of "OK" commands.
Thank you moderator. I need the solution for this string. When
while(strcmp (strx,str1) != 0) ;
if condition gets true what will happen now. I am unable to trigger it out. plz help me.
If what you are trying to do is to wait for the module to send you the "OK<cr><lf>" response a possible implementation could be:
//issue command to gsm module
-- blah
-- blah
//wait for OK response
str1 = "OK<cr><lf>";
strx = "";
fail = 0;
while((strcmp (strx,str1) != 0) || fail = 0);
strx = gets(Usart_Rx_Buffer);
if(strx = Some_other_predefined_error_message_from_module)
fail = 1;
//proceed to give gsm module its next task
Refresh your mind when working with strings. :) Also have a look at The break; statement
https://www.cplusplus.com/doc/tutorial /control/
An important point when writing AT command interfaces is not to rely on assumptions about a specific response format. The first step will be to strip off delimiters and leading spaces.
I don't know what gets() is supposed to do, but I would expect that <CR><LF> is removed from the response string. In this case, the compare would fail.
