GPIO pins in embedded board
nahidalam
Junior Member level 3
I am exploring the capabilities of GPIO pins in the embedded development boards.
Is it possible to connect 1 GPIO pin to multiple devices? Do I need to use some sort of port expander.
Generally speaking,
When configured as output, it is possible to drive multiple destinations with a single pin (without exceeding the maximum current drain of the port of course).
When configured as input, only one source can actively drive the pin - otherwise, conjunction will occur.
This is the general rule (exception do exsist).
using wired-OR, open collector or tristate techniques can enable multiple devices to use a common line, e.g.
https://www.ni.com/white-paper/3544/en/
if using an microcontroller GPIO pin you have to ensure that it has this capability
