Jester
Full Member level 6
![Full Member level 6](/styles/images/ranks/flevel3.gif)
I picked up an older Gould PB54 differential scope probe from an electronic surplus shop for cheap in like new condition. This probe requires power +/-12V according to the probe spec sheet, however no details on the pin-out of the power connector. Some Gould scopes come equipped with the power connector on the back (see image below)
![48974526.jpg 48974526.jpg](https://www.edaboard.com/data/attachments/58/58034-3ea4a86f508ed303b4d052b919379ff1.jpg)
The datasheet for the probe states compatible with Gould DataSys 117 or external power unit (4101380). I searched for both of those and found nothing.
So if someone has a DataSys 117 that can measure the voltages on the power connector that would be greatly appreciated.
Any suggestions on how to determine the pin-out of the connector without damaging the probe?
