cupoftea
Advanced Member level 5
Just spent the day trying unsucessfully to solder a ltc7803 (16MSOP)
At 15:45 of this video
..he uses some clear flux, which is quite pasty, do you know where to get it....he says he buys stuff from BLT circuits, but i dont see it there.
He also says use small conical tip..but i already did that and failed dismally.
Also, howcome he doesnt burn up the solder resist like i do? That burned up, gunged up solder resist really impedes soldering....i find no flux deals with it.
Also, he has the blue solder resist between each pin...thats usually impossible with a 0.5mm pitch chip...how does he manage to get that solder resist inbetween the pins like he does? No PCB manufacturer can do that?
