narayani
Full Member level 2
I have set frequency sweeping using global option frequencies AWR MWO from 3.3 to 4.1 GHz . When I opened new graph as SParameters and tried to simulate it, I am getting different frequencies like 2.2 to 2.4 GHz. How to resolve this issue. My question is, how to get same frequency sweep from 3.3 to 4.1 GHz while simulating also.
I have attached below related screen shots and also .emp file also. Look into it and give solution for this problem.
I have attached CG2H40010F.txt file and change same file as .emp and open using AWR MWO. You can simulate and get sweep frequencies from 2.2 to 2.4 GHz
