May I know how you get 12p.
OpAmp input C also problematic. Cure is small amount of fdbk C. You can derive optimal Cfdbk thru LaPlace analysis,
signal flow graph probably easiest due to number poles in T(s) of the internal/external transfer function. There are tools
on web to make that easy. Dotted line in output graph is for Cfdbk = 0, eg. the ringing case you observe.
The following excellent treatment of problem -
Below dotted line graph Fdbk C = 0, otherwise 6 pf
Regards, Dana.
Thank you...I did not compute (lazy), just tried a value.
Note here also how OpAmp loses control of virtual ground both when slewing
and due to finite bandwidth, but is also helped with Cfdbk, does not fix slewing
problems, if anything aggravates it (effective response) a little (slewing causes
OpAmp to be non linear for slew time , many papers on web about this).
Here the C2 does not work as RC LPF, because the node is virtual GND.OpAmp input C also problematic.
