glcd interface with pic18
balaji3724
Junior Member level 3
hi friends
i need help, in normal lcd(16x2) we can send the data as binary +30 it will display the character llly in glcd where sent the font as image code like using fontcreator or normal hex value?
thanks
But the content does not open (the zip file)
To send a character to a glcd you have to lookup that character from a font table, which then sends out the correct pattern to turn on the required pixels to make up that character.
Before you start using a glcd you have know the type of glcd - say TS12864 , what its driver / controller are KS0107/kS0108 and what you are coding with.
