thestranger268
Newbie level 3
Hi folks,
I keep on getting this error when I try to simulate a liquid crystal cell's transparency for THz applications. Some more facts: the spatial dimensions are 4.525 mm x 4.525 mm x 3.9 mm. The liquid crystal layer is sandwiched between two silica glass plates. I want to simulate the S2,1 parameter for transmission. Therefore the boundary conditions I've chosen are:
xmin, xmax = conducting wall (in reality we will insert copper spacers on both sides)
ymin, ymax = magnetic tangential = 0
zmin, zmax = open
Also I chose the symmetry planes (in order to reduce the amount of mesh cells):
yz: electric tangential = 0
xz: magnetic tangential = 0
xy: none
When I look at the port modes, eveything seems to be correct -- but the simulation won't succeed! I have about 370 million meshcells and I even decreased the transient solver's stability factor by 0.2. I'm aware that this simulation might take a very long time but it throws the error before excitation even begins!
Does anyone have an idea, what the problem could be? If you're interessted in the model, please let me know.
Greetings from Germany,
thestranger268
zmin, zmax = open
xy: none
thestranger268
