dpaul
Advanced Member level 5
Getting problem with CCD check due to use of "generate" block in one design file
Hello all,
I am currently running a CCD check using Cadence Encounter(R) RTL Compiler for an IP which consists several *.v files.
In one of the .v files the "generate" statement has been used -- This is causing an error while I run my CCD script.
Error msg given by compiler:
// Parsing file ~hdl/abc.v ...
// Error: hdl_default_checks/rtl_checks/RTL13.6: Standalone generated blocks are not supported in the IEEE standard
// In line 235, file '~hdl/abc.v'
// Error: Fail to read design.
// Read design summary: Error: 1, Warning: 0, Note: 0
CCD script which reads the design file:
read design -verilog2k -define <company_tech_name>\
-root <....> \
-parameter <...> \
hdl/some_file.v \
hdl/abc.v \
hdl/some_file.v \
-lastmod -noelab
So can anyone please tell me what options I must use so that the error message regarding use of "generate"
statement in design dosen't show up?
Hope I am clear in the explanation!
Thanks & Regards,
dpaul
---------- Post added at 12:02 ---------- Previous post was at 11:56 ----------
The part of the code in the design file where this "generate" statement is used......
// Generate statement to connect memory banks attributes to read/write banks of
// memory controller.
generate
begin
for(i=32'd0; i<SRAM_IF_NO_OF_BANKS; i=i+32'd1)
begin : memory_bank
assign sram_wdata_int[(i+32'd1)*78-32'd1:i*78] = b_wdata;
assign sram_addr_int[(i+32'd1)*
SRAM_IF_BANK_ADDR_WIDTH-32'd1
:i*SRAM_IF_BANK_ADDR_WIDTH] = b_addr;
assign sram_dm_int[(i+32'd1)*78-32'd1:i*78] = b_dm;
assign sram_ce_int = ce;
assign sram_we_int = we;
assign b_rdata = iSRAM_RDATA[(i+32'd1)*78-32'd1:i*78];
end
end
endgenerate
Hello all,
-root <....> \
-parameter <...> \
hdl/some_file.v \
hdl/abc.v \
hdl/some_file.v \
-lastmod -noelab
Thanks & Regards,
dpaul
generate
begin
begin : memory_bank
end
end
endgenerate
